跳转到主内容
由华硕制造的笔记本电脑。
2523 个问题 查看全部
No boot, all leds on except battery and HDD
Hello,
I tried to give as many details as possible to what I did and how the issue came to be.
The story:
I own an Asus R510L laptop. It was resting for a good time without use as it has a keyboard button issue where it was always pressed.
Instead of having it as a nice e-trash, except the keyboard it was a very good laptop for watching movies on a travel. So I got it out of the box and tried to start it.
Absolutely nothing happened when I press the button, no led, no screen, nothing. After a long time in the forums, I had to completely disassemble it and do a bios reset by removing the battery, checked the battery and it was still at 3V which is good.
After the hard reset, the computer came back to life, I was welcomed by the BIOS screen and I was very happy.
So, I turned it off, reassembled everything with the HDD, and I booted it up.
My windows locking screen on the sight, I didn’t go though as the keyboard issue was still there, but I told myself I’ll solve it later. So, I grabbed an SSD I wasn’t using much, I put it in the PC, and from that moment it refuses to go on.
I tried to remove the SSD and try to boot without any drive and the computer stayed off and I noticed that all the leds were on except the battery and the HDD. And there, I tried everything, hard reset, start with only DC, only with battery, reseat the ram and absolutely nothing changed.
The behavior is the following:
On battery: Computer off, when I press the ON/OFF button, leds mentioned above go on and nothing happens. If I long press the ON/OFF button the computer force shutdown successfully and the leds go off.
On DC: Leds goes on as soon as I plug the DC jack, still nothing else happens, no battery charge indicator even with the battery on, when I try to force shut down with the ON/OFF button, the leds goes off for a split second then goes on again.
I have no idea what to do to diagnose the issue, can you help me please ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
What happens if you reinstall the HDD?
完成的
Thank you for the suggestion, for some magical reason, I did put the HDD and the laptop work again...
Also, now it seems that the swap worked and the computer boot normally with the SSD...
Very weird, I am afraid that the issue might come back again after some time, do anybody have any idea where it can come from ?
完成的
添加一条评论
1个答案
已选择的解决方案
@Samy
Just wondering if the BIOS got corrupted somehow and the repeated attempts to get the laptop started again i.e. battery in/out, AC connected/disconnected eventually restored the BIOS to default like a full power refresh does i.e. remove the charger and the battery and hold the Power button operated for 30 seconds to dissipate any residual power from the motherboard thereby restoring the BIOS back to normal.
You said that “It was resting for a good time without use…..”, perhaps now ensure that the battery fully charges and then if Win 10 is installed in the laptop, create a Win 10 battery report to check the status of the battery. Compare the Design Capacity value versus the Full Charge capacity value.
这个答案有帮助吗?
得分 2
1条评论:
This solved it
After starting, I fount out that the battery is in deep discharge state, I just ordered a new one along with a new keyboard. So yeah, somehow just plugging back the HDD solved it….for some reason.
Also to be noted, in my case doing a hard reset had no effect, happy it works again !
完成的
添加一条评论
添加你的答案
Samy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 36
