跳转到主内容
加入维修社区 - 创建账户
衣物干衣机维修和支持指南。
kenmore he5 F25 code
kenmore he5, panel lights work, drum light WILL NOT come on when door open but works with door closed. F25 code, replaced inlet and outlet thermistors, additional code P3E, it just beeps three times when you push start
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Thermal fuse checked out okay
完成的
My apologies, this is a duplicate post.
完成的
@barouquebayou
What is the model number of the dryer?
完成的
Model 110.87088601
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @barouquebayou,
Don’t know the answer but according to the tech sheet : “Opening the door while in Diagnostic Test Mode may not activate the drum light. The light will come on when Start is pressed, or upon opening the door after the Diagnostic Test Mode has been cancelled”.
P3E is a code for the door switch opening test when in Diagnostic mode. Closing the door should give a 8:88 code and a beep.
I realize that you replaced the inlet thermister but did you test its connections back to the control board, you didn’t say? (see wiring diagram on p.12 for inlet thermister control board connection points P4/1 and P4/2)
这个答案有帮助吗?
得分 2
2条评论:
The drum light will not come on when door is opened, out of diagnostic test mode, will test connections and report back.
完成的
We replaced the door switch just now and it works.
完成的
添加一条评论
添加你的答案
barouquebayou 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 227
