跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Preparation for MBP Retina mid 2015 SSD Replacement Upgrade
I know I must make a current Time Machine back up before replacement. But…
  • Should I back up to iCloud right before as well?
  • I know I must prepare/create a bootable drive with Big Sur installed, right?
Regarding all my apps, files, etc. everything that is NOT backed up. I purchased a new Seagate 1TB Basic HD to copy over everything else (apps, files, etc.) too that I will be able to drag & drop them back onto the new 1TB SSD when Upgrade is complete.
Is my plan correct?
The instructions kinda don’t address my queries…
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
TimeMachine will create a complete backup of your apps and data to your external drive.
Making the effort to also create a iCloud copy of your important stuff is not a bad idea. I find having an iCloud drive helpful when I need to access information from multiple devices while on the road. But keep in mind your network connection will hold you back! Most ISP offers for residents are asymmetric connections. Think of it this way you have a dirt road to get to your office (25MPH) in town and a highway going home (75MPH) so it clearly take you less time getting home! Now think about all of your travels how much time you waste getting to work! If you can afford it a business connection will likely be a symmetric connection offering equal speed in both direction, but that is costly!
While having a bootable external drive (USB thumb drive) is very helpful its not really needed. Your system has a powerful feature offering internet recovery and upgrades. Even still I would make one just in case!
Using Disk Utility format a 32GB thumb drive with GUID and a journaled file system, Download the OS installer file from the Apps Store (or from How to get old versions of macOS Then follow this guide How to create a bootable installer for macOS. Double check you can boot up with it.
So the last part of your question what’s not backed up? If you’ve apps from Apples App store you may need to reauthorize them as the drive ID which was used is now different. Some other Apps may have other means to prevent pirating.
And lastly the malware and viruses you still had on your system! But you could pollute your new system if your not careful! Make sure you’ve install and run a good antivirus and malware app before you even start!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ernest James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 61
