跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Phone doesnt power on.
Hello! I bought few phones for really good price, in the bulk was a lot of batteries i tried them all on the phone but only once the iPhone connected to PC in DFU And was charging, before i managed to download the software the phone disconnected and never connected to the PC again. i cant tell if the phone is showing something on the screen because i dont know if the screen works. Weirdly the same thing happend to iPhone 6 Plus that was in the bulk connected once and never again. I even tried all the batteries on the other 6 and 6s Pluses, but nothing happend. Is it the battery? im not sure if its worth to get a battery and test it or could it be something else wrong? I dont even know if the screens are working ..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you have brought a bulk lot of phones you will need a known good working device for each model. You then need to try the logic boards out in the known good housings. This will completely rule out parts as I wouldn’t trust the batteries screens and flex assemblies that came with them.
这个答案有帮助吗?
得分 2
2条评论:
Honestly when i checked the phones out it was 100% Done by someone who didnt know what is he doing. For Example All of the phones had disconnected Charging ports and the screen flex cables are broken to the extend it will not connect to the phone anymore, one of the phones had missing pins on the logic board and it was icloud locked so i just put it in trash. sadly i do not have any 6s Plus or 6Plus to test it out. But i have a 6 that i know is working so i tested the batteries and 2of them didnt show anything and 3rd was bootlooping and then stopped and never showed signes of life. A quick question i know 6s Plus and 6Plus have interchangeable batteries is it ok if i just get for example 6sP Battery and test it on all the phones ?
完成的
@Night Yes, that will be fine.
完成的
添加一条评论
添加你的答案
Night 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 58
