跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Battery doesn't charge after replacement
I replaced successfully the battery in my 3Gs, but when i plugged it for charging it didn't charged at all. It made the typical sound and the battery icon changed to indicate it's charging, but the percentage didn't raise and started to go down until the moment when it is totally empty.
What can I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Try swapping back to the original battery to see if it will charge on your iPhone 3GS. If it does, then you received a defective battery and should seek a replacement.
If it does not charge, then you may have a bad dock connector or a bad AC Adapter.
Did you order the battery from us? If so, then send me an email, Matt(at)iFixit(dot)com, with your order number and I can assist you in getting a replacement.
Replace the 30-pin docking port assembly in an iPhone 3GS and fix problems connecting to USB devices, charging problems, loudspeaker audio, and microphone functions.图片
产品
iPhone 3GS Dock Connector
$19.99
这个答案有帮助吗?
得分 3
1条评论:
Matt, as you guessed, I received a defective battery, because the original battery did not have any problem in charging, so now I am trying to replace the defective battery. Thanks.
完成的
添加一条评论
By typical sound you just mean the little beep right? You ordered an iPhone 3GS battery and NOT a 3G battery right? If so, go in and re-check all your connections, clean them, and re-assemble the phone in the most careful, most meticulous manner you can. If that still doesn't solve your problem, it's possible that you have a blown charging fuse, but let's see if a good old fashioned clean and re-assemble works! Let us know what happens!
这个答案有帮助吗?
得分 1
1条评论:
Philip, I tried to clean everything carefully, but still the same problem. Finally I am sure the battery was defective. Thanks for helping.
完成的
添加一条评论
添加你的答案
Eva M. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 2,246
