跳转到主内容
加入维修社区 - 创建账户
Is this micro scratch?
After successful attempt on removing the anti-glare coating on the retina MacBook Pro screen using Listerine and only using the microfibre cloth and clean it just after removing all the left behind anti glare but when the screen dry off after the cleaning, I can see the screen not shiny like a normal screen it see like a rough texture on the screen but it’s not rough when you touch it. Does anybody maybe this is just anti reflectice that just won’t come off or it are micro scratches? If so how it happened because I’m only using the microfibre cloth to clean it up?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I’m suspecting you haven’t fully cleaned off the coatings.
This also explains your other issue! Dead pixel or stuck pixel on retina screen? As the Listerine seeped under the screen along the edge wetting the defuser sheets MacBook Pro Retina Display Teardown checkout step 12
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
admwitchy 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 10
过去 30 天: 14
总计 281
