跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5197 个问题 查看全部
I received a phone that I can’t remove the two pentalobe screws
hello, I received a phone that needs a battery replacement. I can’t get passes step 1 probably because the last person to work on it over Tightened those screws. How do I fix this isssue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
If the screws are just spinning in place, what you may be able to do is lift up on the screen a bit with a suction cup while turning. This may force the threads on the screws into the metal hooks on the screen and help push them out when you turn them. If the heads are stripped out you may have some luck by placing a rubber band between the screw head and your driver bit and turning while applying some pressure.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Oliver Strubbe 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 14
