please help my camera won’t let me click an answer
hi my camera is stuck on “choose time zone and set date and time” how do i get rid of this. it won’t let me click menu to cancel and it won’t let me choose an option please help
Hi,
Try a power refresh and check if this resolves the problem.
Turn off the camera and then remove the battery from the camera. (see image)
Press and hold the camera’s Power On/Off button for a full 30 seconds and then release.
Reinsert the battery and try turning on the camera and adjusting the settings.
This may not work as there is a backup power supply (capacitor) on the motherboard that maintains the settings when the battery has been removed. If any data has been corrupted preventing normal operation a power refresh may not restore the data back to default. You can only try.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 884
Hi Ashley, have you got any solution for this problem cause I am also facing same issue.
由 santosh shinde 完成的
