跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151 个问题 查看全部
iPad bootloop after throwing due to Roblox server maintenance.
My iPad got trapped in a bootloop after this story: I was playing a game on roblox, but the server went on maintenance. I threw my ipad many times across the room in anger. It worked fine, but it bootlooped after i came back home. It bootlooped and force rebooting did not help ether. The worst case scenario is the SSD broke and my data and the OS is gone. I think my logic board or bios chip is loose. I do not want to lose ANY data. I did not back up iCloud due to the space being full (5GB) I have 128 GB black model.
Edit: It was just a botched update. No physical damage whatsoever. I have a case.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Just connect to iTunes, and enter Recovery Mode, and hit update. After, open photos and go to the top of it, and charge your device, but keep it on. This will recover all of your photos. It worked for me.
这个答案有帮助吗?
得分 -1
添加一条评论
最有帮助的答案
Fix your stupid anger issue first. If losing some data fixes your tantrum, it’s a cheap solution.
As for the iPad damage, if you need to ask, you can’t do it.
这个答案有帮助吗?
得分 1
2条评论:
I clicked update with iTunes, and now it works perfectly fine,my data intact. Learn some manners. I'm reporting you.
完成的
@The Mariocrafter So your anger issue will just wreck your iPad next time.
My manners are reserved for sensible people, you do not qualify.
完成的
添加一条评论
添加你的答案
The Mariocrafter Alt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 225
