跳转到主内容
加入维修社区 - 创建账户
电脑显示器维修。
power supply needs replacement
the power supply burned out on my Dell u2211h ultrasharp 21.5 monitor. its intermal to the monitor. I know I can replace the power supply but cant figure out how to take appart. already removed the 6 screws. there is a symbol that looks like a lock, any help would be appreciated.
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My monitor just go off but the power light is on when the PC go standby the light change to orange color when wake the PC then it on green normal but no picture you can the light flash a little bit second with low bright ….I am confused now the monitor name is viewsonic …VA902…19 inches
完成的
添加一条评论
2个答案
已选择的解决方案
Here is a link for downloading the service manual for your monitor. Good luck.
http://support.dell.com/support/edocs/MO...
这个答案有帮助吗?
得分 2
添加一条评论
after you have taken the screws out, just prey the joint frames that holds the screen panel with a flat screw driver..that should enable you to open the monitor. good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cesare 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 861
