跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
No image, diode readings and connector seem ok
Customer tried to change the screen after a fall, tried with my replacement parts, still no image, connector seems ok, diode mode readings seem ok. checked for LSD, no evidence. Phone boots ok, everything works apart from screen.
What could it be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
We will need some more info. Have you checked it is not the backlight circuit? Depending on USB restrictions will your PC recognise it? What is the reading on the USB ammeter?
完成的
Phone works perfectly, apart from the screen :)
完成的
添加一条评论
1个答案
hello Marco,
turn on thinking :-) if the phone works and you are sure of it. In addition, the measurements also seem okay to you, think more. Every electronics engineer knows that measurement in the diode mode does not guarantee the correct signal in terms of its power and value. If you are sure that the screen is working (I advise you to check it again), the screen is probably not efficientlly powered or has 0V from the motherboard. This is an electrical device - powered by electricity, not resistance. This is a very common mistake of beginners.
  • fingers crossing, regards
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marco Reibaldi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 124
