跳转到主内容
Republic of Gaming laptop released in 2015 . The GL551J has a GeForce GTX 860M video card and a 15.6" Full HD 1080p display.
19 个问题 查看全部
Power on, no boot, no display
Hello,
I’m repairing an Asus ROG Laptop model GL551J. It came in for Power on, no display, no boot. So far I’ve replaced the LCD, LCD Flex, and the motherboard itself. Still the same issue. I tried powering on without RAM and it does not beep or anything. Also has the same symptoms with the HDD removed. I have the stock power supply it came with. Does anyone have an idea on what I should try next?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Laptops can fail to start if they detect residual electricity on the motherboard or its components, which avoids too much electricity overloading components.
Try to boot up your computer by removing unplugging the battery.
If your laptop still won't power up, a faulty power supply, failed hardware, or a malfunctioning screen could be to blame.
To test the display, you can attach an external monitor and restart the computer.
It's very important to actually perform every step in the checklist below if you want to effectively troubleshoot your problem.
https://forums.tomshardware.com/threads/...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
adamkirchgassner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 420
