跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
xbox one s wont turn on and makes clicking sound then turns itself off
been doing this since last month, i try turning it on but everytime the xbox light lights up makes the starting sound, then after about a milisecond i hear a faint *click* and it shuts off right after, please help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I also have these problem
完成的
添加一条评论
1个答案
最有帮助的答案
There are several things that may be causing this. It sounds like it may be a problem with something shorting or with the power supply. It is most likely the power supply. Here is the part you will need to fix it if it is in fact the power supply. Xbox One S Power Supply: Internal Replacement Part (ifixit.com)
Xbox One S Power Supply图片
产品
$29.99
这个答案有帮助吗?
得分 1
4条评论:
It sounds like it would be the PSU.
完成的
@nytryder26 That is what I thought, too.
完成的
I have this same problem, baught and replaced the PSU, and it is still beeping/clicking, could it be the motherboard?
完成的
@Russel Hill Maybe try the Hard drive
完成的
添加一条评论
添加你的答案
eoinye10@gmail.com 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 24
总计 669
