跳转到主内容
Released in 2008. Will have model number KDL-52W4100 the bottom right corner on the front.
3 个问题 查看全部
intermittent horizontal lines on bottom quarter of screen
Sony KDL55W65: Getting intermittent horizontal lines on bottom quarter of screen. 2 seconds of lines, then 2 seconds of normal. Maybe a loose connection? Repairable?
This is a Sony KDL55W65. I chose Sony KDL-52W4100 because it was the closest option.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
loose connection possible. But a loose connection would not repeat an on/off cycle 2 on/ 2 off………..
each section of the screen is driven separately. It sounds like the circuitry for that section has a problem.
It is probably fixable by replacing the driver board for that section (though the board may include all sections). You need to look at whether it is worth the part and time/effort. The part might be used (cheaper) and the rest of the TV my have a smoldering problem (bad capacitors). There is no warranty on anything. New TV will have some kind of warranty.
There may be a Sony specific community forum that will have the exact problem and more info.
这个答案有帮助吗?
得分 1
1条评论:
This is helpful - thank you very much, Bill
完成的
添加一条评论
添加你的答案
Phil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 206
