跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
After SSD add/RAM upgrade MacBook Pro mid 2012 G/CPU run extra hot
Internet research suggests that thermal paste an issue in old Macs. The ifixit guide for this model suggests a high level of difficulty, while redditors suggest that it not hard at all.
Should I just return the SSD/RAM and sell it off with the original optical drive/HDD or is it worth trying to do it? if I’ve managed to do this, the next bit is just a matter of motor skills and following instructions?
Will one of those stores that fix electronics be able to do it or is that too expensive to be worth it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’m suspecting your real issue is your HD SATA cable! Your Hard Drive Cable Is A Ticking Time Bomb and/or your cable is an older SATA II (3.0 Gb/s) version which this series had at the start and then Apple upgraded it and the drive to SATA III (6.0 Gb/s). Many heat issues like yours is due to your system having to work harder because the cable is worn-out or the older version.
Here’s the needed part: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and the guide to put it in MacBook Pro 13" Unibody 中期2012 硬盘线缆替换
Also make sure you clean the dust build top on the fans and heat sink fins and maybe you should install a good thermal monitoring app like TG Pro
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable图片
产品
$34.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Quimper 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 3
总计 144
