跳转到主内容
加入维修社区 - 创建账户
Google 于 2018 年 10 月发布的第三代 Pixel 手机。
Unable to make calls
Had did a factory reset on my Pixel 3 twice and didn’t find any fault in the SIM card given that it works on other devices. Yet, I am facing intermittence with the network and most of the times am unable to make any calls or SMSs. I am not sure if it is an issue with the antennas or the SIM card reader.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @j370,
Not sure if the setting is the same on your model, but check the signal strength of the network signal.
Go to settings->system-> about phone -> sim status.
Remember the signal strength is in -ve dB so the higher the number the weaker the signal actually is.
这个答案有帮助吗?
得分 1
20条评论:
Hi @jayeff, I am getting values around the 100 range. May I also add on that mobile data seems to be working. I have 2 SIM cards, one that doesn't always work on my device and another that is not facing any issues. I am quite certain that the signal around my area is ok as my device was previously working. Not sure what are your opinions?
由完成的
@j370
What is the signal level like with the good SIM card?
Try clearing the phone and messages app cache data Go to Settings Apps and Notifications and select the app.
Try starting in safe mode although since one SIM works OK this may not prove anything
由完成的
@jayeff, that was the signal level on the good SIM card, looking at another device I had, I am quite certain that the signal level is roughly aroung this range. As I mentioned, I had already did a factory reset so I am ruling out software glitches. Starting in safe mode is the weird thing where it works once or twice but mostly doesn't seem to be reliable.
由完成的
@j370
Are both the SIM cards from the same service provider?
由完成的
@jayeff, no they are not. I had gotten a replacement SIM for the one that isn't working so well. Can also add on that both SIMs are unable to place calls.
由完成的
显示更多的15条评论
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 229
