27” iMac 5k late 2015 screen issue.
Does anyone know what I’ve broken here. I changed my hard drive and was feeling quite good with myself. Until I put it back together. Have I damaged the screen or the backlight?
Ouch! You damaged the display when you took it off.
Did you follow the iFixit guide and use the special pizza cutter tool?
这个答案有帮助吗?
Yes I did, then I used the two credit card like things in the kit, but what I didn’t see was any warning about not inserting them in too far and must have been were the damage occurred.
So a new screen will fix the issue and transfer the backlight over from the damaged screen?
@tarx Yes you need a new display assembly. Sadly, you can't transfer the backlight as the assembly as no one offers a raw LCD panel, only there assembly.
Here's the needed part: 27" iMac Retina 5K LCD Panel & Front Glass Assembly, Apple P/N 661-00200
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 77
