跳转到主内容
The HP Pavilion dv6500 is an affordable multimedia notebook with a 15.4" screen , a stylish case, and a security fingerprint scanner.
11 个问题 查看全部
What are the specs for the power supply for the HP Pavilion dv6500
What are the specs for the power supply for the HP Pavilion dv6500? I have lost mine and want to find a replacement.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @advanhorne,
What is the product number of the laptop as found on the information label on the bottom of the laptop?
Looking at the spare parts for the model range, the adapter specifications can vary depending on the product number.
Search for your particular product number in the list provided by the link above and then click on the number to find the parts.
When you have the parts list for that model variant, find the AC adapter part number and then search online using the part number only to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your answer. I will follow up on the links you provided.
完成的
添加一条评论
input : 100-240v -1.6a (1.6a) 50-60hz
output : 18.5 (18.5v) 3.5 a (3.5a) lps
65w
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your answer.
完成的
添加一条评论
添加你的答案
AD Van Horne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 211
