跳转到主内容
Acer Aspire 3 A315-21-92FX is a series of with budget computers designed and sold by Acer. It is one of the cheapest computers in the market. The camera is equipped with 720 pixels HD webcam.
17 个问题 查看全部
Why does it keep shutting off after it goes to sleep for a while?
I plug in my laptop and it is on and running fine. I walk away for an hour or more and then find that it is completely shut off. I don’t know why this keeps happening. I looked at my settings and don’t see anything set to make it do this. Does it need a new battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
click START and type control. CONTROL PANEL will show at the top. Click that. When it opens click POWER OPTIONS. In there you will find options to set when the unit sleeps and when it hibernates. There are also different power options available and all contain those settings.
这个答案有帮助吗?
得分 2
1条评论:
Thank you! I noticed it did say to turn off after 5 minutes in the advanced setting tab of that area. Hopefully this will do the trick. Thank you so much!
完成的
添加一条评论
My HP Pavilion 14m-cd0001dx has done a similar thing after I re-installed Windows during an SSD upgrade. I believe it is due to a feature in Windows 10 where it will hibernate (essentially saves contents of RAM to hard drive, then powers off) after being in sleep mode for a certain amount of time in order to save the battery. There should be an option to turn that off somewhere in the power settings although I unfortunately forget exactly where. I would check that first.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Valerie Konitshek 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 6
总计 33
