跳转到主内容
Also called the Crosley Musician Entertainment Center.
22 个问题 查看全部
CD player broken solutions aren’t working
So I put the CD in and it thinks then displays the number of songs. Sometimes when I press play the light lights up but only after pressing it several times and pressing skip so the display says it’s on the first track. Then it thinks for a second and the disk sounds like it is turning and then the displays says “E” and I’m not sure what to do after that. I don’t think it could get dust in it so I don’t think that’s the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @isabel18,
Have you tried another CD just in case the CD is faulty, you didn't say?
Try cleaning the laser lens (example only) and check if that resolves the problem. You would be surprised how dust gets in to cover the lens. Dust on a CD can take it in and then it is blown onto the lens by the movement of the disc and over time it builds up. Unless you clean the disc every time that is ;-)
这个答案有帮助吗?
得分 1
2条评论:
Hi,
Yeah I tried a couple CDs two of which were new and none of them worked. I just got this and there is a lot of dust in other places so I wouldn’t be surprised if the was the problem. Thank you for the link I will definitely try that. The other places I looked though said that if the CD player pulled the CD in like mine does that was unlikely to be the problem. But it’s so dusty everywhere else… is there anything else you would recommend trying?
完成的
@isabel18
I would try the cleaner first.
If still no good, as you said "I just got this...." does this mean that you bought it from someone?
Contact them about a refund or discount etc if they described that it worked OK as obviously it doesn't.
Otherwise you may have to open it up and investigate further. The problem is that Crosley doesn't release their service manuals publicly and adjusting laser lens to read properly can cause more problems if you don't have the details.
完成的
添加一条评论
添加你的答案
Isabel Manrodt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 40
总计 704
