跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
My ps4 has a problem
My ps4 wasn’t accepting discs all of a sudden,It was accepting yesterday night,today morning I woke up I tried to insert,I couldn’t insert,I have to fight the PS4 to push the cd, I accidentally pushed it thinking my ps4 would work,but I couldn’t play the cd and the cd isn’t coming out,how do I fix it
what Do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Looks like the disc drive has failed and firstly you need to check if the Disc drive is powering on when you turn on the console. If it is, open the console and check the rollers that accept the disc and eject it, most of the times cleaning it will solve your problem.. If the disc drive isn't receiving power then you’ll probably need to replace the drive itself. Cheers :D
这个答案有帮助吗?
得分 0
7条评论:
I tried to insert the disc I couldn’t there was literally no disc there i pressed eject there was sound coming I force inserted it(thinking game would play )but it didn’t and then still I pressed eject sound is coming but no disc is getting ejected and the disc isn’t showing on ps4
The disc isn’t actually showing and I can’t play it
完成的
You will then have to open the disc drive and probably clean it and the rollers and then check if it plays the discs.... There might be a problem with the Disc Drive itself so your best bet is opening and checking.
完成的
How do I not damage it
How do I fix this without opening any components
完成的
If i'm right there is no possible way of fixing it without opening it....
完成的
How do I open it safely?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Habeeb Afraz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 102
