跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 个问题 查看全部
Broken Airport socket connector MBP 15 inch 2014
Hi,
As you can see, I’ve broken the J2 airport socket connector on my MBP 15’’ mid 2014, the cable is fine, yet it does not attach to the board anymore.
My question is can I just solider the cable to the remaining part of the broken socket, or there are better options?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Best to just replace the AirPort board, there is no soldering here its a crimped shell part MacBook Pro 13"/15" Airport Board, Apple P/N 661-8143.
If you must, you’ll need to get a new socket connector and replace the broken part with a fresh one. That’s a bit of a wrinkle! As you’ll need to find the connector from a junker or order it if you can find it.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the answer.
完成的
@drhabib - Don't forget to accept the answer if you are all set - Thanks!
完成的
添加一条评论
添加你的答案
Habib 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 38
