跳转到主内容
CB Radio (all types) first introduced in 1958.
41 个问题 查看全部
Wiring diagram and colors for Cobra 29 LX Max microphone.
All of the wires came unsoldered from the plug on my microphone for my Cobra 29 LX Max. When I take the microphone apart, it appears the two extra wires are for:
Yellow = Extra microphone for the phone audio.
Green = Possibly data for the three buttons on the front. Such as Repeat, Report and Bluetooth.
From watching videos online, I can probably figure out the other four, but I’m not sure how to test for the extra Mic and Bluetooth on the radio side. Not sure which pins they go do. The only pin I’m sure about at the moment is ground is pin #1 as it’s the only one that didn’t get broken off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I found my multimeter and watched several videos. I figured it out. This is according to the pin numbers on the plug for the microphone.
Pin 1 = Ground = No shielding
Pin 2 = Audio = Black
Pin 3 = Transmit = Red
Pin 4 = Receive = Blue
Pin 5 = Blue Tooth = Green
Pin 6 = 2nd Microphone = Yellow
这个答案有帮助吗?
得分 3
1条评论:
Also note, If audio only works when you turn on Talk Back, then the Receive wire is never making connection to ground when the key is depressed. The audio is MUCH louder when the receive wire is connected properly.
完成的
添加一条评论
Screwdriver
BellsCB.com
这个答案有帮助吗?
得分 1
添加一条评论
Please guide me in VHF Radio company I.Com model 5023
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jdavis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 173
总计 3,620
