跳转到主内容
加入维修社区 - 创建账户
Keyboard dead, won't recognized by computer
Hi, I saved this keyboard from the reciclyng yard since someone in my office has thrown it away. The reason is the keyboard is not recognized by any computer when plugged in the USB port. Even the led on the caps key won't turn on. I tried to open it in order to see if the USB cable was damaged but everything looks in order (I tested with a multimeter). Am I completely hopeless or is there something I could check in order to try a repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Give this vid a view Trying to FIX : Faulty Apple Keyboard Model A1243 purchased on eBay
这个答案有帮助吗?
得分 0
3条评论:
Yeah I already saw that video. You're telling me that my keyboard is probably water damaged and there's no possibility to repair it? My keyboard does not work at all nor is recognized by any computer, while in the video the board is recognized and have some dead case.
完成的
@ilmatte - Likely too far gone ;-{
完成的
Additionally, the USB hub of my keyboard simply doesn't work, while in the video it does. I think the case is not the same of the video since I see no signs of corrosion. I think it's something not working in the electronics but I don't know how to investigate. When I attach the USB cable the keyboard is not recognized by the system, caps led doesn't turn on and the only sign of activity is the chip on the left side of the logic board that gets hot...
完成的
添加一条评论
Apple &&^& us to buy another $@$*
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matteo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 42
总计 749
