跳转到主内容
The ASUS Transformer Book Flip TP500LA is a 2-in-1 laptop with a 15.6-inch screen and a 360-degree display.
15 个问题 查看全部
Why do my USB ports constantly connect/disconnect when on AC power?
This is a two-part question. Both parts are directly related.
1.) When my device is charging (AC Adapter plugged in), my USB ports don’t function properly. Devices with a large current draw (I.E. my iPhone) constantly connect & then disconnect. Low-power devices (I.E. usb mouse, flash drives) function fine.
2.) When I unplug my device from AC power, the USB ports function fine with all devices, but my screen flickers.
I’ve eliminated the possibility of this being a software bug, it happens even in BIOS settings & on multiple OS’s.
I have a feeling this is something to do with a ground issue, or a power circuit, but I don’t even know where to start when it comes to those things without proper information. Which is why I’m here.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @did2010 ,
If Win 10 installed, create a Win 10 battery report to check the status of the battery. Compare the Design capacity value versus the Full Charge capacity. If the battery is failing it may be that the charger has problems supplying enough power to run the laptop and charge the battery at the same time. The same when the laptop is on the battery. Power fluctuations from the battery may cause the screen to flicker
Did you try a different compatible charger, you didn’t say? This is just to eliminate the possibility that there may be two separate unrelated problems i.e. USB power/connection problem with charger connected and flickering screen without it.
What is the motherboard’s board number (printed on the motherboard somewhere)? Search online for (insert board number) schematics to hopefully find them. Maybe try here. This will make it easier to start testing the power supply rails on the motherboard.
Just some things that I’d try.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Devin Deville 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 192
