跳转到主内容
戴尔上网本包括Mini 10系列的维修和支持指南。
17 个问题 查看全部
My Inspiron 7579 is crashing. Help.
The computer is crashing and BSOD always shows up. I’ve tried blowing on the fan, but it didn't help. help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Provide a image of the BSOD or the error code, photo would be more useful
完成的
添加一条评论
3个答案
已选择的解决方案
BSODs are usually software-related. Try resetting your computer by going to Settings -> Update & Security -> Recovery. Under the Reset this PC, choose Get started. Follow the prompts.
This will remove your apps and settings, but may prevent further crashes.
这个答案有帮助吗?
得分 0
添加一条评论
I am going to say that by you laptop crashing, then it does come up. If so go to Event Viewer and then Window Logs and see what might be causing the issue. Also the BSOD error would be helpful. Check to see how much RAM you are suppose to have verses how much RAM your system is showing you have.
这个答案有帮助吗?
得分 0
添加一条评论
First take a data backup of your important data now try reset the settings of your laptop as it was new. If it didn’t work then just change the window of your laptop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
normal person 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 91
