跳转到主内容
How to install macos
I’ve tried multiple times to install macOS any version of really I’ve tried the apple conventional ways and I keep getting the same error saying that the macOS lion isn’t available trough the AppStore I’ve tried to install it with a USB but the computer will only let me boot trough internet recovery can anybody help ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your system can support macOS High Sierra (10.13.6) which is the highest OS supported.
To get it you’ll need to get the OS installer from here How to get old versions of macOS. You’ll need to create a bootable OS installer from another Mac system following this guide How to create a bootable macOS High Sierra installer drive
Then boot up using it using the Option (⌥) key to get to the Startup Manager so you can select it as the boot drive
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 1
6条评论:
What can I do if i don’t have another Mac?
完成的
@hakarou321 - Is your system booting up at all with the OS it has?
完成的
Nothing when it boots I just get a folder on the screen or I can try booting to internet recovery
完成的
@hakarou321 - See if Option-Command-R works or Shift-Option-Command-R
Reference: How to reinstall macOS
完成的
They all lead me to internet recovery and I can’t seem to install macOS x lion again it says « The Item is temporarily unavailable, try again later »
完成的
显示更多的1条评论
添加一条评论
添加你的答案
hakarou321 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 199
