跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
How do I fix drift
My left analog keep drifting. Started off jut forward and now does it in all directions. Strange part is that even when I don’t touch it out of no where will start drifting forward around 15 seconds later.
I cant see a guide on here about replacing the hole joystick mechanism but only the caps.
Controller hasn’t even been used a massive amount. Been sat around doing nothing for most it’s life.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You can somehow unclip and bend out the potentiometer part of the joystick just enough to clean the insides. Replacing the joystick mechanism would require desoldering tools and temperature control, otherwise you’ll overheat the board and solder pads get torn off.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
CnPx 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 953
