跳转到主内容
Repair information for the Fitbit Charge 2. Released in 2016. Model number: FB407.
18 个问题 查看全部
Best way to clean USB 2 port?
The watch isn’t charging. I’ve tried cleaning with alcohol and Deoxit. I would like to get something to slide to the bottom of the prong in the port to clean the contacts. A pin is too thick, and toothbrush bristles are hard to create pressure with. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
I know this isn’t an Iphone but I recommend trying this method:https://youtu.be/3v5qRlPa-dk and/or https://youtu.be/fMuXpt9NdN8
这个答案有帮助吗?
得分 0
2条评论:
Thanks for responding. I’d already tried those options, fail. I think a solder connection cracked, it’s kaput.
完成的
Oh ok, I wish you the best of luck
完成的
添加一条评论
添加你的答案
William Evans 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 227
