Radiator fan turns on late
My radiator fan kicks on at 220f, works for less than a minute and off it goes. ive changed the thermostat, the sensor on the thermostat and the sensor on the radiator but still have the issue, any suggestions?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 62
When the motor kicks off is voltage still being sent to the motor?
由 brandon k 完成的
Im not sure, it turns on for less than a minute and off it goes..
由 William Rivera 完成的
check with a meter and see. If you are getting voltage then the fan motor is bad. If not, you'll have to trace the circuit back from there to find the issue.
由 brandon k 完成的
