跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Why is my iPhone 6s+ not getting activated after restore?
My Iphone 6s+ suddenly shutdown while using and it wouldn’t turn on so i tried to put it in recovery mode but nothing was showing up on the screen so i directly plugged into my laptop with iTunes then i got a dialogue box saying your iphone is in recovery mode you have to update and restore it, so iTunes downloaded it and extracted it and only then i could see apple logo and my phone turned on like a new phone but it when tried to set it up i was asked to put in the sim card to activate it but it did not activate i was getting an error “unable to activate with red caution symbol“ so i tried to activate it from pc but no luck i got the same error in the pc i attached the pictures .
Then i logging in to find my phone in iCloud and removed it from the account, and then I tried it but still no luck, i put in recovery mode and restored it but i still got he same error.I tried it couple of times but i still got the same error. Then i contacted apple advisors they told me to do every thing i did again but still didn’t resolve the problem and they said to go the nearest apple store but my nearest apple store is 1000km away .
The strange thing was i was able to see LTE but my phone was not showing any WIFI networks even if i literally put my phone on top of my router.
I am not sure what else is left to try I really need help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your phone cannot activate because it needs the information from the Baseband CPU which it is not getting.
 You can confirm this by inputting *#06# into your phone keypad, it should bring up your IMEI number or you could connect it to your PC and use a program called 3uTools and see if it shows your IMEI there. If it doesn’t I would be looking at an upgrade as it will be an expensive repair.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your response, it does bring up my IMEI number when i type *#06* so what can i do now?..is there any way i can fix this..
完成的
添加一条评论
添加你的答案
Kopparthi Jashwanth Rami Reddy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 113
