Sony Xperia XZ Premium not charging or turning on
I have a Sony Xperia XZ Premium for about 4 years, has worked fine up until now. I got a battery low warning the other day and hooked my charger up - original plug & cable - the phone powered off immediately.
I held the power button and the Sony screen appeared as normal, but the device again powered off straight away. If I left the charger connected it would go through this loop repeatedly, and also the charging light was erratic - flickering green, flashing red etc. It was the same whether I connected it through a wall socket or to a computer, the Xperia Companion app wouldn’t detect the phone either.
I tried a new charging cable but that didn’t fix it. After a day or two, the Sony screen no longer appeared when I held the power button or connected the charger - instead I got the usual battery icon that appears when the phone is powered off and charging, except rather than there being a charge % and the icon filling with green, there was no % and just a single red line in the icon.
I took the phone apart and replaced the charging port - no change. I then replaced the battery which didn’t fix it, but rather put the phone back in the same state it was when it started having problems initially - repeated Sony screen boot loop.
Would appreciate any suggestions!
I have exactly the same problem but if I apply pressure to the bottom right of screen app 2 cm from charging port and 1cm up, it will charge. I also replaced battery which was faulty and charging port but this problem then occurred. I believe it is a motherboard problem as the board to board connector is located in this area and I may have damaged it when replacing the battery.
由 Timothy 完成的
