跳转到主内容
Surface Laptop是微软Surface产品线中的第一个全笔记本,在2017年6月发布。
105 个问题 查看全部
My screen cracks and pixelates in black screen
On my Surface Go, never dropped or messed with, the screen just started to freak out in certain colored screens. Black is the most noticeable… i’ve rebooted, and restarted three times.. no difference as far as i can tell. The problem… persists
please tell me this is a fxable solution, cause this piece of equipment is rendered useless with the screen like this, and I cannot figure this one out
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Those lines down the screen are not a good sign.
Try connecting an external monitor to the mini DP port and check the display on it.
If it is OK then the problem is either in the laptop’s display panel or the cable connecting the motherboard to the panel, but I’m thinking more likely the panel.
Here’s the Ifixit 微软 Surface Laptop拆解 guide. that may help but it seems that the laptop is not an easy one to gain access to, to fix.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
garrettcrouch217 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 57
