跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Wireless Charging NOT WORKING
iPhone 8 wireless charging Not working!
The phone charge normally with the USB charging cable, but when i put in the wireless charger it does not charge.
The FPC connector good not damaged. All caps are good no damage and no short.
Sometimes the phone turns off randomly even with Brand new good quality battery.
Any suggestion what to look for? Should i change the wireless charging IC?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Have you tried it in a known good housing?
完成的
@imicrosoldering Yes! The same. I assume it's a board level problem. But on the iPhone 8 the is NO schematic. :( Hard to rack down the charging lines.
完成的
@peterhupuczi check out northridgefix on yt hes got a ton of videos you might be able to find something
完成的
There is plenty of iPhone 8 schematics, if you don’t want to pay for zxw or wxj you can download refox from rewa.
完成的
添加一条评论
1个答案
已选择的解决方案
There might not be iPhone 8 schematics out there but there are iPhone 8 plus schematics which will have the same wireless charging circuit. Before you start replacing chips I would take some multimeter measurements.
You need to follow the voltage from the coil to the diodes than to the wireless charging IC than to Tigris. If it is making it to U3400 but not Tigris I would check R3410 and R3420. If it is making it to Tigris I would look at Tigris and Hydra as I think Hydra has to okay this circuit. One of these two IC’s could be causing the phone to restart as well.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Peter Hupuczi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 280
