跳转到主内容
The Bose QuietComfort 20i are in-ear headphones from Bose. Released in August of 2013. Model number: 362544-0010.
12 个问题 查看全部
Modding Bose QC20 to use dc power?
My bose Quietcomfort 20's battery is dead... I know some online vendors sell compatible batteries and controllers and there are videos on youtube explaining how to replace them.
However, since I mainly use the qc20 at home for noise-canceling and don’t need/want to keep buying li-ion batteries, I wanted to know if there is a way to attach an external dc power adapter instead? The battery is 240mah 3.7v, I'm not sure how to find something like that in a power adapter. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If the battery is still alive, you can charge it while using it. A power bank, because an AC based charger can introduce buzzing. But not all power banks are likely to do it, since it draws very little current. My best performing power bank for small current will work for a while and then I have to push the button so it starts again.
I have read somewhere that Bose put limitations in place so it won't work if the battery is actually dead. They put in other limitations, so that's not unlikely.
You've probably made other arrangements, but putting it here for others with similar questions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark Roi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 64
