跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
Which replacement battery should I get?
So my MacBook Pro 15" Retina A1398 (Mid 2015) A1398 needs a battery replacement.
I am so confused and can’t decide which one to get, since I haven’t found any with great reviews, some people are complaining about the Ifixit ones (which was my initial choice) same for those on amazon, the one that has somewhat decent reviews claims to have up to 500 charging cycles (which is so low comparing to the original one up to 1000)
then there is the Duracell, Newertech and Greencell
which one ??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Sissi,
I came across your post and I wanted to share some information that might help you make your decision regarding your future new battery. First off, I wanted to let you know that we offer full warranty for our batteries, so if it’s not working upon arrival, customer service can send you a new one or issue a refund (click here to see our EU warranty information.) If for any reason, you have any problems with our batteries or you have any questions, our EU Customer Service team would be happy to chat with you. You can get a hold of them at eustore@ifixit.com.
At iFixit, we sell a lot of batteries and when things go wrong, our customers often turn to our Answers forum to find a solution. This is great because it is why this forum exists! Our community is made of people helping each other out. When someone buys a battery that works out of the box they won’t have an issue to share, so you won’t necessarily hear what their experience was—but that means they can help!
Best of luck with whichever battery you end up purchasing!
这个答案有帮助吗?
得分 2
添加一条评论
Hi Sissi:
My suggestion would be to go with a new Duracell battery. Duracell is a leading company in this area. So, I think you can’t go wrong with it.
Steffen
这个答案有帮助吗?
得分 0
8条评论:
They resell Power2 batts not their own.
完成的
aren't they good?
完成的
Hi Sissi,
Dan makes a good point.
When it comes to replacement parts for Apple products, I usually look out for original ones.
Here is an original Apple battery for your MacBook Pro, however, from a seller in Britain: https://www.ebay.com/itm/282897002666?ep...
Maybe you find such a seller in the US, or you might want to get in contact with this British seller. Maybe the seller is open to ship to the US.
Just an idea...
Steffen
完成的
I am from Italy @tekki
完成的
Hi Sissi:
That might be a perfect solution for you. The British seller also ships to Italy.
Steffen
完成的
显示更多的3条评论
添加一条评论
添加你的答案
sissi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 868
