跳转到主内容
Informative guides for home coffee and espresso machines.
1485 个问题 查看全部
Coffee Maker Internal Nylon Piping & Crimp Terminations
Hi All,
I repair bean to cup coffee makers on a regular basis and need to find a supplier of 4mm nylon pipe and in particular the crimps that are applied to each end. The pipe is 4mm outside diameter and 2mm internal diameter. If I knew the generic terminology it would help with my searches. Many thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you mean high-pressure pipes with readily crimped ends, made from Teflon? Look for the appropriate length.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neville Thannhauser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 24
