跳转到主内容
Technique for replacing belt
Have this Hilti DSH600X power saw. Been trying to replace the drive belt . It's a serpentine belt. Been trying to heat it in hot water so i can stretch it enough to roll over the front blade pulley. Just can't do it. Wondering if there is an easier method? Can't find any adjustment screws or slide. Anyone know about this?
Thks, Charles
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
I did two of these belts I used long 3/8 extension One end of the extension on the pulley nut with the belt on extension and stretch You got tie the saw down so it won’t move you really got to stretch the belt
这个答案有帮助吗?
得分 1
2条评论:
So pretty much, Hilti wants you to send tool into them to do any maintenance.
完成的
Thank you I will try that!
完成的
添加一条评论
Think about this. The mfg put it on with ease, you should be able to also. The has to be an adj since belts stretch.
This is for a Stihl but I am betting it is similar https://www.youtube.com/watch?v=a7cydlI8...
Or you could go here and chat with Hilti customer service https://www.hilti.com/content/hilti/W1/U...
这个答案有帮助吗?
得分 0
添加一条评论
What is the belt number that fit the dsh 600x concrete saw
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charles Goossen 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 46
总计 2,198
