跳转到主内容
Where can I buy a PCIe to USB Adaptor?
My 11” MacBook Air (2013) recently died and I have opened it up and removed the blade SSD.
Beyond buying an older MacBook Air and connecting the SSD into it (I don't have the money for that), does anyone recommend any USB adaptors I can connect it to?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
First Apple uses a custom SSD so you need a special case to hold it: OWC Envoy Pro Portable, Bus-Powered USB 3.0 Storage Enclosure for select Apple Flash SSDs from most 2013 to 2015 Mac Models.
Reference: The Ultimate Guide to Apple’s Proprietary SSDs
这个答案有帮助吗?
得分 0
添加一条评论
AMZ has a number of options. Aliexpress also has a lot if you can wait for it.
这个答案有帮助吗?
得分 -1
4条评论:
Thank you for your response. Are you able to provide a link to the product page?
完成的
Just search for "nvme to usb" == Since I am not an Apple tech I can't vouch for the fact that the RAM is a std NVMe format. Can't see why it wouldn't be, BUT
完成的
@ruggb - Sorry not so simple! Apple did their own thing! You need the correct interface, the M.2 interface is very different. Read the links I posted.
Think of it this way a US power plug won't work in the UK and most of Europe without an adaptor! And you still have to deal with the voltage difference.
完成的
Of course they did their own thing, so they can charge more money. That is a primary reason I am a Windows tech. Not saying it is perfect, but I have a big problem with vendors who sell things for 3x what it is worth
完成的
添加一条评论
添加你的答案
Joshua Gershinson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 51
