跳转到主内容
The Husqvarna YTH20K46 is a 24-horsepower lawn tractor or riding lawnmower with a cutting width of 46 inches.
11 个问题 查看全部
My lawn mower runs but cuts off when engaging the blade
I have a craftsman riding mower and it idle’s up and down, then when you try to engage the blade it cuts off I have changed spark plugs, cleaned the blades, and checked the belt, all is fine
I need some suggestions on what I should check next I was going to check to see if the fuel solenoid is bad that it's not getting enough fuel to operate the blade but not sure
Please help thanks and God bless
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
When the blades are engaged the throttle is adjusted to support the load. It sounds like that linkage isn’t working.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
douglasbeverly1854 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 355
