MacBook does not boot and kernel panics. FIX?
Hi,
I have a 2010 13” 2,4ghz MacBook Pro. The computer does not boot and would kernel panics usually. Here is every OS I tried
Snow Leopard Installer On USB : Goes to Apple Logo and tries to boot but kernel panics halfway.
Yosemite On Internal Drive : Boots halfway crashes and has shows some error log text and has a “NO” sign a few seconds later (occasionally kernel panics)
Yosemite On USB: Same issue as internal drive
Yosemite Install USB: Boots, but “unmounting disk” error when installing
This computer seems to be very tempermental. I gave up and came to the answers community instead. I also tried to reset the PRAM and Option+D and Cmd+R. I don’t know about the logic board. I took the computer apart and I didn’t see any problems. And also the fans run at full speed for some reason, Just a side note. And also I am not using AASP’s. I have already wasted enough time there. Thanks guys!
UPDATE : 5/18/2021
I tried yosemite on an USB and now it will only go 20% in the apple logo progress bar and it will just stay like that forever and doesn’t go any further.
After trying Snow Leopard, the internal drive doesn’t work. I think it’s the SATA cable, but I am not going to fix it until i can get the computer into an operating system. The computer also doesn’t accept : Option+D and Command+R for some reason.
UPDATE: 6/2021
The laptop did boot into every version of macOS using safe mode, but only El Capitan/Lion works using normal mode, but it is EXTREMELY laggy and unusable? Can I still revive this motherboard?
And also the battery doesn’t work, just another side note
3条评论
The panic report often gives clues on what the issue is, I would review it.
Also I would run the on board diagnostics. Restart your system and press the D key to enter.
由 Dan 完成的
@danj It will just say the normal panic. It will just stay like that forever
由 ryoseo1020 完成的
@danj the computer also would not boot from a working copy of Yosemite for some reason. It would only go to 20% and stay there. I wonder if the MOBO (Motherboard) is still fixable.
由 ryoseo1020 完成的
