跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Replaced Front Face Assembly, Touchscreen Only Works When Opened
I replaced the touchscreen on my iPhone 6 about a month ago (actually, the whole front assembly) and it (the touchscreen) will be responsive when my device is open. But, whenever I put back the screws and cover plates and close the phone, the touchscreen is unresponsive. Over time, I opened it multiple times, replacing the screws, one at a time, to see if that was the problem. Nope. Same problem. When open, it works; when closed, it stops working. Frustrated, I put the phone away. Yesterday, I opened the phone and moved the screen a bit without disconnecting anything (not the cover plates or the cables) and the touchscreen responds. I close it, it is unresponsive.
This is the second screen I purchased. I had the same problem with the first assembly and returned it. When I replaced it with the second one, it didn’t make sense to me to return it because the part does work but for some reason, every single time I close up the phone, the screen doesn’t respond. The front facing camera works, the home button works when the device is closed. It’s just the touchscreen that doesn’t work when closed.
An iPhone isn’t supposed to be open with its guts exposed to work. I thought about keeping the cover plates off for the battery and front assembly cables but, in my mind, these parts serve a purpose and make me leery that the phone will malfunction even more so than before so I put them back where they’re supposed to be. What could be the problem? Any assistance will be appreciated. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’ve had this problem before and 100% its the touch flex cable. It’s quite possible that you have gotten faulty parts, It’s happened to me before that multiple parts have been faulty. On the other hand make sure you are lining up the cables correctly when installing the back plate. If they are out by a little bit it can cause a sharp bend in the flex causing the touch issues you’re having. The cables on the third party screens are very thin and easily damaged so just make sure they’re lined up correctly and that you’re not applying too much pressure when installing the back plate.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
T.A.U. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 17
