跳转到主内容
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 个问题 查看全部
Rear running lights do not work?
The rear running lights do not work on my 94 GMC Sierra . My turn signals and hazards are fine. and brake lights work when I hit pedal , but my tail lights that stay lit while driving do not work and I have changed the bulbs already and no fuse is blown. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If fuses and bulbs are fine then check the switch. Make sure that it is supplying the running lights with power when selected. If not, and you've got power coming into the switch, then you need a new one. If it IS sending power to the lights, then you'll need to trace the wires back and make sure they aren't broken. If the power wires aren't broken and you're getting power to the lights, then you'll need to chase down the ground.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Von 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 29
过去 30 天: 113
总计 2,095
