跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Replaced screen and touch not working after set up
I replaced the screen and the touch worked while setting up, then stopped working after download was completed from other phone. Any thoughts on what I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Alberto,
There are two possible reasons. First, you have incorrectly inserted the screen connector responsible for the touch function. Turn off the phone, disconnect the battery, unplug and plug in the touch connector again. After being turned on, the phone should respond normally. Be sure to check the operation of all buttons, including Touch.ID. Another possibility, the replacement screens sometimes stop working for no apparent reason. Delicate and non genuine electronics in Chinese screens, sometimes incompatible in the cheaper ones, is the cause of many problems. Starting from the touch, through hanging the whole ios, up to complete darkness. Check the screen if you have the option. Maybe go to a repair shop to have them check there. In case of problems, return the screen to your dealer or request repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alberto Tirri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 44
