跳转到主内容
This is the Asus - VivoBook X540SA-BPD0602V 15.6", (1366x768) Laptop which contains an Intel Braswell Quad Core N3700 1.6 GHz processor that supports turbo up to 2.4 GHz. It contains 4GB of RAM and a 500GB hard drive.
15 个问题 查看全部
Is this RAM compatble with my laptop?
My actual laptop is a VivoBook X540MA - Intel Celereon N4000 1.10GHz with 4GB of RAM.
I checked in the task manager how many slots were used in my laptop and I found out it was already full. 4 out of 4 with 1GB modules installed each.
I was wondering if I would be able to upgrade it with this RAM:
Kingston SODIMM DDR4 8GB KIT 2400MHz CL14 HX424S14IBK2/8
VDD 1.2 V
VDDQ 1.2 V
VPP 2,5 V
VDDSPD 2.25 V - 3.6 V
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I just did a little research on your laptop. Unfortunately it looks like the RAM on the whole X540 lineup is soldered to the motherboard and cannot be replaced or upgraded. The reason task manager shows you have one slot is because Windows has no way of knowing if RAM is soldered or socketed. If you need more RAM, you will need to get a different laptop, even if you got another motherboard they only ever made them with 4GB of RAM from my research.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
naigen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 84
