Is a dead gamecube port on a Wii fixable?
So to give a description of what happened. I accidentally shorted the data pin with the 5V pin while the console was on. The console still works perfectly fine, but the port does not work at all. I want to see if there’s a component I can get to swap it out.
umm first off howd you end up doing that and have you tryed to see if a trace bruned out ima try find some more info
由 keith s.b 完成的
