跳转到主内容
Released in February, 2014 this model, the NV480, is Shark's attempt at an affordable , professional grade, household vacuum.
9 个问题 查看全部
Floor suction works but wand and handle have no suction.
Floor nozzle works/has suction, but removable wand for accessories has little to no suction. All hoses were checked (and double checked) for a blockage, dust cup checked, all filters cleaned per manual, including HEPA. Manual maintenance says close suction control on handle to increase suction but there isn't one. Support could not identify problem but offered to send a new motor.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The ones I have seen, the wand is connected to the end of the hose that goes to the brush, or have a mechanical diverter that redirects the suction to the wand.
If the brush has suction, there is no reason to suspect a bad motor.
这个答案有帮助吗?
得分 0
1条评论:
I just knew it wasn't the motor! Last ditch effort, I threaded a flexible coiled drain tool into the end of the handle. There was a bottle cap wedged in a bend in the handle! The tool was able to bend enough into the spot that it pushed the bottle cap sideways and out it came! I had figured the other tools I tried just wouldn't bend far enough!
完成的
添加一条评论
添加你的答案
Janie Charms 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 73
