跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Hold switch not working after replacment
Hi
I have just replaced the volume and hold buttons on an ipod touch 4th gen. The old ones worked, but I snapped the thin cable when working on it so had to replace it. Now the volume buttons work, but the hold switch will not. I have checked the solders and they're fine. I think the replacement may be defective, because I cannot think of anything else. If anyone has any suggestions I would love to hear them as I do not want to wait three weeks for another hold switch.
thanks alot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
If the solder is fine. Did you check for small tears in the cable?
Make sure there are no solder bridges or loose components near the solder area. If all is well you will likely have to order a new one
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
matt prior 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 585
