跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
After SSD install, OSX? (iMac 2011)
I just put a new SSD in an old iMac and ran up against the “OSX Lion" won’t install” issue (not sure why Apple discontinued the ability of Lion to install in recovery mode). Thinking I will have to create a bootable USB, but does it have to be Lion?
Can I put Sierra or even High Sierra on the system?
I assumed that, since this system was never updated beyond Lion, the firmware never updated and it wouldn’t install an OSX later than Lion from a bootable drive.
Am I wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Here’s the source of the older OS’s How to get old versions of macOS
As you can see you’ll need to run through a few upgrades to get the highest version your iMac can support. So from Lion you’ll need to get to macOS Sierra 10.12.x then if you want go to macOS High Sierra 10.13.x.
I’ll warn you High Sierra created a big change with the file system jumping from HPS+ to APFS if you have a SSD installed. I would hold off jumping to High Sierra which is the last official OS version your system supports.
Here’s the needed steps to create a bootable Sierra OS installer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Onlyififonly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 234
