"Battery was not detected" after installing iFixIt-supplied one
I carefully removed the old, cleaned the case, and installed the new battery, but now the computer says “The battery was not detected Reference Code: PPT001”. I triple-checked the battery control connection, as well as the power connection to the battery itself, and everything appears correct.
Here is what it looks like:
Everything else on the laptop is working properly.
Is there any other test or diagnostic I can run, or should I return it?
I really hate to imagine removing this battery and replacing it. Before doing that, is there an easy way to test the new battery before I do the installation?
Take a tight picture of the small ribbon cable connections (both sides) so we can make sure its installed properly. Post them in your question (edit mode) 在已经存在的问题里加入图片
由 Dan 完成的
@danj Thanks. I just posted a picture of the small ribbon cable connection.
Did you want both sides of the cable, while it's unplugged? Or one of it fully plugged in? If the latter, that's what I supplied. Thanks!
由 David Van Maren 完成的
@djvanmaren - I suspect you got it half way its in your media manager box not posted here in your question
由 Dan 完成的
@danj Thanks for bugging me about the images.
I cannot seem to get the little cable to go any further into the connector.
